It is currently Mon Jun 23, 2025 3:46 pm
PostPosted: Wed Mar 08, 2006 10:00 am
Last Name: Beaver
City: Lake Forest
I'm thinking I could have more creative room if I cut my own veneer strips into purfling but, I've had limited luck using a razor blade. (tends to split the wood) Any suggestions on how I could do it?
Thank you......
Joe Beaver
Maker of Sawdust
PostPosted: Wed Mar 08, 2006 10:06 am
There are several ways to do this. One way is to use Shane's fret cutting table saw blade. Because of the thin kerf you have very little waste.
PostPosted: Wed Mar 08, 2006 10:12 am
i always use a fresh xacto knife and just take lots of very light cuts, i almost never have a splitting problem
PostPosted: Wed Mar 08, 2006 10:17 am
Last Name: Beaver
City: Lake Forest
The saw blade and light cuts both sound like good ways. I guess I do tend to lean on it and try and cut all the way with the first pass. When I lam a few together the saw blade sounds pretty good.
Thanks guys....
Joe Beaver
Maker of Sawdust
PostPosted: Wed Mar 08, 2006 10:25 am
Some guys use this.Its a pasta cutter and it really works.Its not mine,just a pic I saw on some other forum!
PostPosted: Wed Mar 08, 2006 10:38 am
Last Name: Beaver
City: Lake Forest
That works... If you make to much you can always boil and eat it!
Joe Beaver
Maker of Sawdust
PostPosted: Wed Mar 08, 2006 10:41 am
Courtnall's book 'Making Master Guitars" has two methods of making purfling/binding descrbied in detail.
Cheers Martin
Sounds like Im really plugging this book...I do find myself referring to it thouigh on a very regular basis.
PostPosted: Wed Mar 08, 2006 10:44 am
You could try something like this, below. Or make one of your own out of a couple of strips of wood & a blade. Mexican luthiers use a 'cuchillo' and scrap wood.
CrowDuck
http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229 &Action=Catalog&Type=Product&ID=14568
Chris Nielsen
Soquel, CA.
PostPosted: Wed Mar 08, 2006 10:56 am
Michael Mcbroom uses the pasta cutter method.
Which reminds me I haven't seen Michael or his wonderful 10 String Guitars around the forum lately, any one seen him ?
PostPosted: Wed Mar 08, 2006 11:02 am
To give credit where due, I think (not positive mind) the pasta cutter idea is a Grant Goltz innovation, man he is one clever guy, never cornered and his solutions are always first class.
PostPosted: Wed Mar 08, 2006 11:16 am
guys the photo of the pasta cutter is not viewable,(for me) is it one of those 10-12 inch wide things with two rollers that you crank on the handle ?? I hate ask a silly question, which cutter? I prefer linguini..
PostPosted: Wed Mar 08, 2006 11:54 am
Yes thats the type mike
PostPosted: Wed Mar 08, 2006 12:05 pm
Does that pasta cutter REALLY work?
PostPosted: Wed Mar 08, 2006 12:33 pm
I dunno, but I'm digging mine out tomorrow. I'll let you know.
PostPosted: Wed Mar 08, 2006 4:00 pm
A couple other ways (other than alienating yourself from moma).
1) Veneer Saw (Lee Valley sells them)
2) Pattern cutter (basically a wheel with a very sharp edge (Lee Valley sells them)
3) Kinda what Robbie suggested -- I use a thin kerf blade like a Diablo -- set the fence and run a block of scrap wood over the blade -- then clamp it to the fence. This keeps your fingers away from the blade and acts as a hold down for your stock.
PostPosted: Wed Mar 08, 2006 4:31 pm
Thanks for the wealth of info on this guys, i'm gonna try making my own pretty soon!
PostPosted: Wed Mar 08, 2006 6:57 pm
[QUOTE=John Kinnaird] Does that pasta cutter REALLY work? [/QUOTE]
Works like a dream!
PostPosted: Wed Mar 08, 2006 9:02 pm
I have been using a 30" paper cutter (you know, big chop arm) for the past
29 years. It works pretty well.Howard Klepper38785.2107291667
PostPosted: Wed Mar 08, 2006 10:37 pm
Dunno but I guess if you stuffed up a few purflings you could serve them up to your dinner guests as pasta and see if any of them were honest enough to tell you your cooking was cr*p.
Cheers Martin
PostPosted: Wed Mar 08, 2006 11:15 pm
First name: Pete
Last Name: Liccardello
City: Eden Prairie
State: Minnesota
The handiest tool I've found for cutting purfling strips from veneer and other materials is this Micro-Mark wood strip cutter:
http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229 &Action=Catalog&Type=Department&ID=30
It's easily adjustable and the blades are cheap!    Peter J38785.3082523148
Peter
PostPosted: Thu Mar 09, 2006 3:28 am
The pasta cutter works well, wet the veneer down throughly with warm water to soften it up and don't try putting too wide a strips through at once or you will strip the gears of the machine. No more than about 4" max at a time, less if it's harder stuff, sprinkle with a little grano-parma and a drizzle of truffle and garlic infused extra virgin olive oil, serve with a full glass of robust Shiraz or if you prefer something a little more supple a cheeky little merlot with a full round finish would do quite nicely.
PostPosted: Thu Mar 09, 2006 3:57 am
Funny ,But apparently it does the job! Yeah..Thats where I found the pic,Grant Goltz uses it
Thanks Kim DaveAndy38785.4990046296
PostPosted: Thu Mar 09, 2006 8:46 am
Here's the MicroMark wood strip cutter, Item # 14568
http://www.micromark.com/prodimgs/14568.jpg
CrowDuck
Chris Nielsen
Soquel, CA.
